tjiniowa
Where do I find the serial number for G955. Just got it home today would like to find out more info about it. Runs but needs a few parts like tie rod end, steering cylinder leaks, injection pump leaks, lights don't work, just a lot of little things to get right. Does anyone know how much oil pressure it should have, the gauge doesn't read very high, but I am wondering if it is electric and not working right, or maybe it needs bearings checked. I am going to change oil in it first because I don't think it has been done in a long time and it has been sitting for 2-3 years. Thanks
Serial Number plate is below steering wheel, clutch side, above platform. Just like an Oliver as they were built in Charles City. Built in 1973 and 1974. First 1974 number is 244 599-251 357. Oil pressure should above 25 psi, never below 10 psi. Gauge just uses colors. Should be in the green.
Good for you, here is ours. Dan pretty well covered things. The oil psi is electric and ours runs way up in the green on the color gauge even when the engine is warm @ an idle.
Brad
