My 445 has 3 hyd levers on the right side. Two of them are for the remote cyl connections. They seem to work fine, are both plugged, but you can tell when either one is moved at idle the engine pulls down a bit. The third lever is for the lift arms. when i move the lever up about 1 inch the arms go all the way up. If i touch the lever down just a hair the arms will stop. Ive tried moving the two levers under the seat, made no change. Clueless as where to start. When tractor not running the lift lever has no resistance for about a third of its travel. It will just fall to bottom
of its travel. Any help or direction will be appreciated. Pump seems good and strong no noise or whine.
