We have a single block U in the shop and have come across an issue. In reassembly rod caps 2 and 3 have absolutely no end play while 1 and 4 are just fine. We had the crank machined but did nothing to the rods themselves. We installed the caps the way they were removed. I'm sure we are overlooking something simple, does anyone have any suggestions?
It is possible that these 2 rods are out of a different tractor as at one point the tractor did throw a rod out the pan. How much of an issue could this cause? The guy we got it from said that it did run good but sat around and got stuck.
