Minneapolis Moline GT
What would a Minneapolis Moline GT be worth, ballpark? Complete, very straight sheet metal but rusty, decent tires and rims, currently not running but ran last year so wouldn't need much more than a battery, gas, and tune up to get going. What would it be worth as it sits? What would it be worth running?
M- M made the G T tractors from 1938 thru 1941. After that , they were called GTA s. Latter they were called " GTB s and then the GB models until the end of production..
Acording to my master list of models and production numbers there were 1262 GT tractors built.
Gt used the GE motor same as 21-32 and FTA with open flywheel. Most never came with
electrics. Some had the cable controlled starter but very few had a generator. Tires are an
issue as they all has 12 x 32's which are hard to come by. GT in 1940 has a S in serial
number. GTS. Only GT's had red grill. GTA had PG1 same as rest of tractor. A good running
GT with decent rubber should be worth 4-5k. There is not many out there. Blocks can be
tough to find if needed.
The very late models did come out with 30" rubber on them. I have complete set of tires rims and hubs I took off one going to the scraper to put on mine that has 32" rubber on it.
Parts book only shows one size. FT5715 solid center. My 1940 has 32's. MM U had 30 inch rims available in 1941 bur center would have UT number. Mushy what is your center number?
Learned something new. I thought the
GTA was the first after the merger:
formerly a Twin City. Looks like I
learned something new today. Tractor
data shows the GT was a 4 speed trans,
too, rather than a 5.
(quoted from post at 08:34:39 03/23/16) The very late models did come out with 30" rubber on them. I have complete set of tires rims and hubs I took off one going to the scraper to put on mine that has 32" rubber on it.
img]https://forumphotos.yesterdaystractors.com/photos/34334.jpg[/img][/img]
