MM 445 Utility Tie Rod Ends
445
Does anyone know where I can get tie rod ends for a 56 MM 445 Utility or what can be made to work? I have one that needs to be replaced and I am not finding any replacements.
My 335 utility has Jubilee Ford tie rod ends, (the rear ones, normally at the Ford steering box) that have the threaded stud on them at an angle- inboard of the tie rods. The angle they make is a little crazy, but they've been on there for over 10 years. I do not know if you can make them work on a 445 or not, there is some difference in steering gears.
The outside tie rod ends are from some John Deere, (I think.) Back then the aftermarket books had the dimensions in them. I did have to drill the setscrew dimple in the shank of the Deere tie rods, they came with grooves in them.
