MM trip plow
Hope someone can help. Been in a re-build and fix up mode lately. Ready to repair and make useable a MM plow I have, It is a 3 bottom "Trip Plow" that has been modified at some point to be able to fit with a cylinder and use it with hydraulic power to raise it out of the ground. Wish I had a model number, looks to be 16 inch mold boards, but the shares are wore real bad. Anyone here steer me to a supplier that could furnish new plow shares for this? I looked a bit on line--no luck yet. Thanks for the help.
If it is a 2 bottom with 3rd bottom add on it is a model AF plow, model DFs were a base 3 bottom with 4th add
on bottom. The plows with the add on bottoms had a small "I" beam on the top connected to each bottom. I may
have some shares that are very good condition. I will have to take a look.
