This picture is of a 10A4213 head on our 5 Star pulling tractor. This seems like a weird crack. Especially since both heads are cracked the same, and both heads are cracked the same on both ends. Meaning two heads and 4 cracks. All very similar. My only thought is that this engine was put together by someone who didn't believe in torque patterns or torque wrenches. Which is believable since the center main bearing was spun and a wrist pin was eating a hole in a bore. Lesson learned about buying a pulling tractor off craigslist!! Haha oh well. So this bears the next question. The tractor was 4.8125x6. The crank is now 6.25. Do I find 4213 heads to replace these? Or is it time to upgrade to square port 30's or 32's? No matter what it will be expensive. I think these heads could be welded too if all else fails. Now for the next question, this tractor has a weird double valve spring set up with shims. This seems foolish to me on an engine running 1800 rpm in a hobby stock class. The valves should never float at that low of rpm, so why the extra spring? It just would be adding wear to the cam in my mind. Thanks in advance for the help guys.
[/URL][/img]
