Model U wiring
I bought a model U, awhile back, have been working on it as time allows, was told it was running, then parked. I replaced gauges and on/off switch, checked to see if the positive side of the coil was hot with the switch on, it was not. Someone replaced all the wires, because they are all new and all the same color, but apparently did not put them back correctly. I can get the coil wired correctly, but I am sure I won't get the voltage regulator wired correctly. Does anyone know where I can get a wiring diagram for the U. Thanks
Here's a diagram for later letter series with distributor and generator
