M-M single front wheel .
Dalex
A friend gave me a yoke and wheel for my single front Farmall "C". As I was cleaning the rust and grease off it a M-M marking came up , and a stamped JT27964 came up next . On the hub half there is a JT , and separately 2788D is cast into it. Clearly not IH ! So what did this come off of , and how does the spindle come out ? I'm going to try and pound it out with a soft hammer, but will check back for answers in a while ...TIA...
Single front setup was used on Z models. Bolt goes up in center of fork to yoke for crank. Bolt comes down from top to yoke. Bearings on top and bottom of yoke. Part number ending in 4 is actually an A.
Ok , Soft hammer did the trick , spindle and bearings are all on the bench , and now it has an identity !! thanks again ...Dale
