The power steering lines on y 445 utility have two hoses that go over the bell housing and join a steel line coming from the hydraulic pump and a steel line that goes in to the power steering pump at the front of the tractor. One of my hoses blew out right by the fitting so there is no way to splice it. The fittings on the hose are inverted flares and no one seems to have them to make me new hoses. The original part numbers, 10A8028 and 10A8029 are stamped on the current fittings so I assume they are original to the tractor. I have gone to several places that make up the hoses and they all have the male end but not the female end that I need for the hose. Has anyone else had these hoses replaced and where did you get them? I was told by one place that the fitting I needed was a 06-07FF. Someone else suggested running hoses all the way from one end to the other, but I am not sure that is practical.
