MM RTU Hand crank
Probably a worn out post to a old question but worth the ask. Does anyone know where I can find a hand crank for my MM R? I have called every tractor scrap yard I have seen listed without finding a one. I just wonder if I should see how close another tractors crank comes and use it. Thanks for the input.
Seems to me the hard crank to come up with would be the one for a RTS or RTI. The narrow 2 wheel RTU or 1 wheel RTN crank is common with the ZTU, ZAU, and ZBU and should be fairly easy to find as there were more narrow fronts built.
The RTS crank is much longer, it goes all the way through the front bolster.
I have seen them fabricated from a 1" diameter bar(at least I think its 1") with a 3/8" tapered pin in the end to turn the crank jaw.
