Still tinkering with this 445 I got. All the pics of the 445 I can find show it with ig switch, amp, water temp, oil press, and choke cable. This is how mine is laid out. I can find the gauges, and i can find the complete cluster with gauges including the tach and speedometer. The complete cluster looks to be a little different shape or size, and i question if it fits the same. I don't care about the speedometer, but is there a small mechanical tach and drive cable available that would work? By the way my 445 has the fuel sender, tach drive on eng works, and the speedometer drive as well. I can make a new bezel plate to match what I got and mount everything. All the sheet metal is off the tractor right now for painting and now would be a good time to these changes. Any help would be greatly appreciated, thanks!
