Bryce Frazier
Hi guys! I am looking for the O rings, and seals needed for the 3 point rock shaft on a 445 MM?? I have looked all around, and can't seem to find anything? A customer has one of these, and it is leaking oil, which then drips off the right lift arm.
All I have to go on at this point is an IT Service manual from him, which isn't that great. It DOES show me though, that there is an O ring inside each hub, and a press in seal in the outside of each of the hubs as well. Can I just replace the seal, or should I pull the hubs off as well, and replace the o ring too? I am planning on new seals on BOTH sides, eventhough only 1 is leaking.
Where can I get two of these things??
