I recently picked up a 1958 mm445. Have not gotten a manual on it because cant find one im sure it will cover what i need. First question, everything i read refers to the ampli-tork trans. Mine only has the factory plug where the handle would go if it had one.
I assume this is normal and my tractor is only a 5-speed. the tractor runs like a top, no problems except the PTO runs all the time. The handle moves freely and locks in to engage, but when unlocked (moved forward) it wont stop. Cant stop it with my foot applying pressure. Previous owner said with a shredder hooked up it would not turn unless engaged. is there an external adjustment for this or do i have to pull the top off of trans housing. Any help would be greatly appreciated, thanks
