Vista hyd and steering
dieselbob
Been working on a vista this winter, the power steering doesn't work very well. What is the gpm of the steering pump? The front end is free. Also what is the gpm of the main hyd pump? Was thinking of putting in a flow divider and doing away with the steering pump. Not sure why MM used a separate steering pump, sure would have been easier to use a flow divider than all that apparatuses. Bob
Do you have a tractor with a closed or open center system?
The big giveaway for the closed center is the large Vickers pump.
