This message is a reply to an archived post by TERRYDFOSS on March 02, 2010 at 19:55:50.
The original subject was "Re: g1000 to bosch inline injection pump parts".
terrydfoss i believe i talked to you several years back about changing injection pumps and turbo charging an old 504 in a g-1000. We did end up using a p-pump off a mack truck and injecting a little water/methanol. The pto dyno we use can only hold 300hp and we were able to lift one of its tires off the ground and barely even load the engine. have ran it like that for several years and have finally found time to build another g-1000 with a 585. have the engine in getting pump/turbo setup figured out. what did you run for a turbo? Im looking at a t4 flange s366 borg warner or similar. Would like a S467.7 but thats a good bit more money. am open to suggestions. Also was curious what pump and mods you were running and how much power can be made with the 585? Can a cummins p-pump be turned clockwise and still deliver fuel? have ran into some pumps that can and some that cant. would prefer a cummins pump due to ease of parts and already having an extra one laying around but if it doesnt work.... Am also waiting on a 4cyl inline pump to be built that will be running on a turbo charged M5. thanks again. Eric
