Mounting A Remote Hydraulic Pump On 602
KCTractors
Location
Central Wi
I want to mount a hydraulic pump on a 602 to use for the loader. I am using the hydraulics from the tractor now, but the loader is rather slow. I was thinking if I could fine a gear box from a belt pulley and then drive a pump from there. I would like to keep the PTO free to use.
Anybody have any suggestions?
The only comment I am going to make is I used to work with several different hydraulic pump engineers and they always said minimum speed for any off the shelf gear pump should be at least 1200 RPM. You can also over-speed them.
The simplest and cleanest way to install another pump would be to try and find a side mounted industrial pump that fits right in the belt pulley opening on the left side of the tractor directly under the 3PT rocker shaft. It was an option for all MM Ind. tractors. It would then be controlled by the PTO clutch lever, and would be live. Also in cold weather you can disengage it to cause less drag on the starter.
MMDEL
I have one on a Mo400 and one on a Motrac. But do not have an extra. I don't think? I am not at home right now as I am nursing a broken leg at my son's place in CA. I have a supply of used pumps but I would have to look when I get home in a couple of weeks. Advertise on here and Tony's web site. Gravitt in NE might have one, or Mike Ahlers in MN (spelling??) I don't have their info here. I'm sure someone else on here will have it and maybe some more suggestions.
MMDEL
