Diesel cams
I dont know the answer but I believe hes asking if the lift and duration of the lobes is the same not if the cam out of a 6 cylinder will fit in a 4 cylinder.
That would happen to be the case. Have a 336 sitting in the shop that is real easy to take measurements on, but want to tweak a 504 that is in a tractor.
Do you have a service manual on the two engines? The wear tolerances of the cam should at least get you close.
