Wuehler2090
New User
I have a U MM that I'm turning in to a pulling tractor. I bought a M670 engine to use for some parts. I'm needing some help and advice.
Which rods should I use? The original ones or the those from the the 336? Can I use the push rods and rocker arms from the 283?
Where should I go to get overbore 336 pistons? Does anyone have a recommendation on having the camshaft ground? Do I need to get a gasket kit for both the 283 & 336 engines. I plan on using the original crank, crank case, the 336 blocks, the 4232 heads and manifolds from M670. Which carburetor should I be looking for? Are there any other issues to consider when making this conversion?
Thanks for any help on this.
