Removing jugs
toolz
What's you favorite method of breaking the jugs loose from the crankcase? This is on an HD800.
I have had very good luck using these scrapers for breaking blocks and heads loose. They do far less damage than a chisel. If that doesn't do it, remove all of the studs and try it again.
https://store.snapon.com/Striking-Scrapers-Scraper-Striking-2--P644924.aspx
A heavy and stout 4" x 6", couple feet long, used like a battering ram. You may be exhausted by the time that old gasket lets go but with the wood, you won't break anything.
Curt
