mm GTC LP gas boils over in radiator
jmducks1
Mm GTC LP runs great but boils over in radiator. The radiator is all cleaned out and there is no thermostat. What can I check out? Boils over just by diving it a mile.
Sir,
Is there visual flow in the radiator when she is idling? I have seen impellers strip on the shaft because of corrosion.
Best of luck.
Charlie
Thanks I will check next time I start it. Sounds legit. If it doesn't have flow then I need a water pump then?
Are you "boiling" over or foaming out? Without a thermostat, that water pimp can actually move coolant too fast and cause foaming if antifreeze is in it. I had this problem with an M5. I could run water with no thermostat but with antifreeze I had a foam problem.
CC
(quoted from post at 04:24:37 12/14/15) Mm GTC LP runs great but boils over in radiator. The radiator is all cleaned out and there is no thermostat. What can I check out? Boils over just by diving it a mile.
Need to make sure it is "boiling" and not just foaming out. On all my G's and GB's that I run anti-freeze in I keep the level low, maybe 1" not more that 2" above the core.
If it is boiling then your pump impeller has a problem.
