Correct spark plug for UB propane
If you are going to use it and pull it you want the coldest plug you can find. I use AC "C81" in all the tractors I farm with. If they are just going to putts around then it can be a little hotter. Problem is the plug companies are discontinuing some of these cold numbers. Also I found that some of the late conversion charts converted a C81 to a much hotter number in their line. If you are working an LP tractor to it's fullest a hot plug will preignite the LP fuel. The gap on an LP engine should be .015 this is in your MM tractor manual. A wide gap in a higher compression LP engine will not fire under load. (Test this in a spark plug tester, the higher you increase the pressure the spark will fade and die.) The LP engine burns so clean you din't need to worry about a close gap fouling out.
MMDEL
Thanks. I was using too hot of plug. I simply was replacing with what was in it which may be why they weren't lasting.
