Pics-4 Bottom MM Trail Plow
1206SWMO
What model and about what year is this hydraulic lift 4 bottom MM plow? I'm too lazy to dig out my old sales literature...I picked it up 30 miles from home in 2014..
Would be a model DF plow, Im guessing late 1940s to late 1950s. Not a lot of the 4 or 5 bottom plows in that style left. Good find. If you need any parts for the hose mast, I did make some reproduction parts for them a few years back.
Thanks guys...MM trail plows are very hard to find in my area,especially a 4 bottom one..I knew that I had to have it...One moldboard is bad but other than that its pretty good..
Depending on where the moldboard is bad, you can weld in a piece of regular steel and it will work. I did that on my AF plow that was wore out where the shin would be and after it got shined up you cant even tell where it was repaired.
Blaine, what model Case combine do you have in the shed there, Strawboss (Brad) is looking for a I think a "120" to help fix his up
Dan
