Ralph wd45
I need to impose on you guys, to answer a question for me. Perhaps the answer is staring me in the face, but I can't see it! What I need to know, is where the two fluid lines connect to the Hydraulic unit.( power steering pressure, and return lines) The tractor is a 57 335 utility with amplitorque, and originally came with power steering, which was stripped off when I bought it.I have assembled a mounting bracket with a chrysler mini van rack& pinion power steering unit, and need to run lines to the units control valve. My IT manual showes the lines on the left side of the engine, and disapearing into the sheet metal under the gas tank. Where do they go from there? Do they cross the tranny, and get attatched to the hydraulics under the seat? IT manual doesn't mention power steering, when numbering, and explaining the port plugs, on the block under the seat. It has three ports for remotes, and a port for plugging in a test guage. Please help. If it's in the manual, then I couldn't find it. Ralph
