1966? Minneapolis Moline Bucket loader/backhoe.
caddyman1960
New User
Ok here is the problem i have. I purchased a Minneapolis Moline bucket laoder/backhoe. The side of the bucket loader says Minne Mo. But when i look it up. It comes to a Big Mo bucket loader/backhoe. I can't find the Minne Mo anywhere. The number i got on the engine #10A6500. Model #1500 Serial#21400209 Backhoe model#B13 Serial#21500160. so there is were i'am at with it. It has 16.9/24 rear tires. So can anyone explain that to me as they keep saying it is a big Mo. Is this model more rare? Sincerely Paulie.
Serial numbers aren't tractor numbers. Serial number is on transmission housing below brakes. 10A number is crankcase number. 13 number is backhoe number.
Paulie,
You have a Minneapolis Moline loader backhoe. Big Mo is the model of the tractor. It could be a Big Mo 400, 500 or 600
industrial tractor. The serial numbers you listed are for the L500 loader and B13 backhoe attachments. The tractor will
have it's own serial number plate on the side of the transmission housing. It will also have a separate engine serial
number tag on the side of the engine crankcase. Post the tractor and engine serial numbers and we can help you nail
down the model and year.
Brian
Ok the serial number for Minn on tranny is #1630 then says #168003. Ok the bucket loader says Minne Mo. The stickers are faded out & look original from factory. The tractor is pelling badly & needs sand blasting. I'am not sure if i can post a picture to show.
You're missing several digits from each of those numbers. The engine serial number should be 1630XXXX and the tractor
serial number should be 168003XX. From the 168003 number I can tell you it's a Big Mo 500 built in either late 1961 or
very early 1962 as 16800391 was the last 1961 model.
Thank you for replying so Quickly. This tractor was siezed up for 10 years & 4 weeks after purchased i got it running with very little money put in it. It does not smoke & runs with full power. The hydrulic hoses are all rotted & have been replacing them. As cash flow is low. So when the hoses on bucket loader & backhoe are replaced. What price will i be looking at to sell? It needs paint job brake work & clutch as it worn down. Maybe some minor stuff also. About average what it would go for.
