G1000 Vista charging ssues
S J P
My Vista is showing a charge rate of 50-60 amps at full throttle. Would this be the voltage regulator causing this? Also have been burning up point sets. Is this caused by the high amperage?
Thanks Steve
Put a volt meter across the positive & negative terminals on the battery. I would think at wot it would show around 13.5vdc with a good battery. If it is running @ 14.7vdc or higher then the regulator is not backing off. I would be surprised if that is your point problem.
