jr1983
Well I guess my three point is going to go on hold
fora while. I finally pulled the heads on my ub and
the front jug is split in the number two cylinder. I
think I could get a set of 336 jugs for it. I know this
can be done but what else is installed in making that
work? Do you use 283 rods? What heads? Any help
would be appreciated.
Check piston deck height when using 336 pistons. Will work on 283 rods but you may have to use thicker or double crankcase gasket to avoid piston hitting head. No big problem.
