G1000 distributor
hrRoss
looking for distributor parts for G1000 MM. need the spark advance springs (2) and possibly the plate that the points mount to. springs are about quarter inch long. any help? thanks 920-562-7890
Should be a tag on the housing below the cap. It will be similar to the tags on the starters and generators. only smaller.If it is still mounted on the tractor it probably is on the back side.
MMDEL
you can by a recurve kit for a GM HEI distributor at the auot parts and get new springs and weights.
