R steering wheel
I don't know of anyone that does them anymore. Since many tractor manufacturers used suppliers for some parts, you might get lucky enough to find another make that used the same size.
If it is just cracked up & no pieces missing, you can take epoxy & fill the cracks. then sand it down & paint it black. It'll look as good as the effort you put into it.
I rebuilt mine using bondo,just grind out all bad spots and fill and sand and refinish.I put on several coats of laquer and work it down with steel wool between each coat,then clear coat it.
