UTC takes same amount as all U's. 52 quarts. The drop boxes are separate.
I filled the transmission and the oil is going into the drop boxes, the seal between transmission and drop box must be leaking. Is there any issue with running the tractor like this? Rather than a couple quarts of gear lube in the drop box there is approximately 3 gallons.
