Jerry Grant
The starter on my 46 ZTN needed to be replaced. I got another starter off of a ZB and had it rebuilt. The battery cable attached directly to the starter post on the original starter. However, the starter from the ZB has a 3 terminal solenoid. I have several wiring diagrams but none show how to wire the extra terminals. Does anyone have a wiring diagram showing where to run the extra wires? The terminal opposite tractor side has a copper strap that is attached to the starter post. The battery cable attaches to the other side. There is another wire on this same terminal that appears to run to the ampmeter gauge. No idea where the small wire that attaches to the top of the solenoid runs to. Will this starter with the solenoid relay work on my ZTN or should I just remove the solenoid and attach the battery cable directly to the starter? My email is open but noted her as well. [email protected] Thanks in advance for any of your suggestions.
