MM GVI With Coolant In The Oil
skycarp
I have a '57 MM GVI that is showing coolant in the oil. Where is the most common place that this would be coming from? Where to start my search?
Thanks in advance,
Dean
There is a weep gap between the water pump and the housing it mounts to at about the 6 o'clock position. Use a small screw driver to remove any grease and dirt that may be plugging weep gap. If coolant comes out of the weep hole, your problem is likely the water pump seal.
OK, I found what appears to be green staining on the lower face of the pump to case shim, which would lead me to believe that coolant is leaking past the seal.
I need a source to purchase the seal, a set of shims and a cover gasket. Any suggestions, I tried NAPA with no luck.
TIA, Dean
