I've got a G-900 Diesel that I've had for years. Doesn't get much use but we put it on a rock picker this spring with my son running it. Anyway, something happened and it died and wouldn't start so we pulled it back to the yard. After sitting a couple months I put in a new battery and turned it over, nothing, so opened a couple lines up and the pump bled out and she started. Only now, I left the new battery connected and it was drained the next day. Now the regulator seems to be taking current with the key in the off position, not in the on position?? Also it shows charging about 10 amps with the key off, O with key on?? Also the temp gauge will try to top out in the off position, read normal in the on. Anyway now I have to unhook the battery every time or leave the key on to hold a charge after running it. Any ideas, yes, the battery is hooked up negative ground like it always has been. Does this sound like a bad regulator or what could do this all of a sudden?
Thanks in advance.
Thanks in advance.
