Continental Energy Cell's
dkeav
Does anyone know the specs on the Continental D193 like used in the Farmall 350 diesel? Pictures of the Energy cells look identical to the MM but I imagine they are smaller, if not I've found some sources for the continental ones. Otherwise does anyone have source for good MM energy cells?
Did M M use the same size energy cell in the different size engines? I am used to Oliver's and they had 2 different sizes. What is wrong with your energy cells?
I think MM used the same size in most of their engines from the GBD-670 or so. I've got a UBD special that I had two power cells you could see daylight through. Wound up having a cracked head as well and found some replacement heads, another one was cracked but had two better power cells in it. So now I'm down to just one cell that leaks fuel out of the head. The head it is in was a NOS, and machine shop checked it out for me. I've moved the power cell to different spot and the leak follows. Any ideas?
(quoted from post at 13:23:41 06/18/15) Just measured the cell. The two pieces are .968 long and 1.015 in diameter.
Awesome work, thank you. I'll measure some MM cells this weekend and see how far off we are.
(quoted from post at 19:32:03 06/19/15) How can I contact you?
My email is open at dkeav zero 4 at gmail.com
I measured the MM cells, they are 2.1325 long without the chamber cups (which are good) and 1.125 on the threaded end.
Here is an example of one of my bad cell's, the one I have installed now that is leaking a bit has a pinhole in the front of the nozzle, this one was really bad and is completely eroded.
