Stacking hay earlier and the hydro pump on 602 looks like split in the center section on left side. Is this possible or something going on I do not know about. May need pump or sell tractor.
Call us, we have reconditioned pumps, but you may have other issues, the pumps don't split just 'cause they feel like it, Dale and Doug, riverdalefarmshop.com, 920 295 3278
Probably best to just sell it and forget the pain it has caused. I will offer you an embarrassingly small amount for it. (I own two already.)
I have a M602 that my Dad had and over the years and several hydralic pumps were replaced. Some may have came off U302 tractors which we had which were almost the same. Some cracked and others needed the coupling sleeve and others just wore out. When I was using mine I accidedently lifted a planter when I wanted to put it down and blew out the O-ring & stripped short bolts so these things happen and it was not a big fix.(just happened when it was not convenent)
If you want to give your tractor away that is fine but the next one will likely have these kind of problems to. It is called basic maintenance.Cleddy
