G705/MF 97 brake discs
Hey all,
Does anybody here know what the thickness of the brake friction material is supposed to be on the brake discs in a G705/Massey 97? My local Agco dealer says the discs are obsolete and can't get them, so I'll have to get mine rebuilt locally.
Also, there's oil leaking out of one brake housing. I would imagine the seals cross reference to something still available, correct? Being as Agco can't get them either.
Im actually having some made now that rivit onto ur
disks instead of the factory glued on style. I should
get them with in the next week or so I hope. Are you
looking for two or 4 sets?
I can't help on the brake discs, but I do have this cross reference between MM seals and Timken seals. Once you have a Timken number, you should be able to cross reference to any other brand. Also I don't know if all MM seals are listed here. Hope it helps.
Paul
MM Seal Number Timken Seal Number
1 0 A 1 0 1 1 1 MN-MO ....................... 6703S
1 0 A 1 0 8 9 4 MN-MO ..................... 450474
1 0 A 1 1 6 0 8 MN-MO ..................... 472234
1 0 A 1 1 6 5 8 MN-MO ..................... 455479
1 0 A 1 4 2 5 7 MN-MO ..................... 455006
1 0 A 1 4 2 6 2 MN-MO ................... 415281N
1 0 A 1 4 8 9 4 MN-MO ..................... 465379
1 0 A 1 5 5 0 6 MN-MO ..................... 455479
1 0 A 1 6 3 2 9 MN-MO ..................... 350954
1 0 A 1 6 3 2 9 WHITE ....................... 360954
1 0 A 1 6 4 5 0 MN-MO ..................... 471883
1 0 A 1 6 5 0 7 MN-MO ..................... 456013
1 0 A 1 7 3 2 1 WHITE .................... 455995N
1 0 A 1 7 3 2 2 MN-MO ..................... 455479
1 0 A 1 7 3 5 7 MN-MO ..................... 455146
1 0 A 1 7 8 1 7 MN-MO ..................... 415379
1 0 A 1 7 8 1 7 WHITE ....................... 415379
1 0 A 1 8 1 7 0 MN-MO ..................... 416380
1 0 A 1 8 1 7 0 WHITE ....................... 416380
1 0 A 1 8 1 7 6 MN-MO ..................... 415304
1 0 A 1 8 1 7 6 WHITE ....................... 476470
1 0 A 1 8 6 7 8 MN-MO ..................... 450067
1 0 A 1 8 8 1 1 MN-MO ..................... 450444
1 0 A 1 9 4 4 6 MN-MO ....................... 50462
1 0 A 1 9 4 4 6 WHITE ......................... 50462
1 0 A 1 9 7 2 0 MN-MO ..................... 416664
1 0 A 1 9 7 2 0 WHITE ....................... 416664
1 0 A 2 0 1 0 7 MN-MO ..................... 416404
1 0 A 2 0 1 0 7 WHITE ....................... 416404
1 0 A 2 0 3 1 6 MN-MO ................... 471268N
1 0 A 2 0 7 9 6 MN-MO ..................... 416047
1 0 A 2 0 7 9 6 WHITE ....................... 416047
1 0 A 2 0 8 5 9 MN-MO ..................... 473231
1 0 A 2 0 8 5 9 WHITE ....................... 473231
1 0 A 2 1 1 1 MN-MO ....................... 473237
1 0 A 2 1 1 2 MN-MO ....................... 455355
1 0 A 2 1 1 2 WHITE ......................... 455355
1 0 A 2 1 1 3 MN-MO ....................... 455011
1 0 A 2 1 4 2 3 MN-MO ................... 415991N
1 0 A 2 1 4 2 3 WHITE .................... 415991N
1 0 A 2 1 6 9 1 MN-MO ..................... 473016
1 0 A 2 1 6 9 1 WHITE ....................... 473016
1 0 A 2 2 0 9 2 MN-MO ..................... 471272
1 0 A 2 2 0 9 2 WHITE ....................... 471272
1 0 A 2 2 3 0 8 WHITE ....................... 470954
1 0 A 2 2 5 1 5 MN-MO ..................... 473225
1 0 A 2 3 9 2 6 MN-MO ..................... 472012
1 0 A 2 3 9 2 7 WHITE ....................... 472012
1 0 A 2 4 1 1 MN-MO ....................... 455004
1 0 A 2 4 1 1 WHITE ......................... 417316
1 0 A 2 4 9 0 MN-MO ....................... 450519
1 0 A 2 6 1 1 4 MN-MO ..................... 415379
1 0 A 2 6 1 1 4 WHITE ....................... 415379
1 0 A 2 7 3 0 MN-MO ....................... 415984
1 0 A 2 7 3 1 MN-MO ....................... 46827S
1 0 A 2 9 2 9 4 WHITE ....................... 296470
1 0 A 3 1 0 3 3 WHITE ....................... 415088
1 0 A 3 4 1 7 MN-MO ....................... 473463
1 0 A 4 7 3 1 MN-MO ....................... 471424
1 0 A 5 1 0 4 MN-MO ....................... 455364
1 0 A 6 2 8 9 MN-MO ....................... 416404
1 0 A 6 6 2 7 MN-MO ....................... 473473
1 0 A 6 7 3 2 MN-MO ....................... 417344
1 0 A 6 7 3 3 MN-MO ....................... 410190
1 0 A 7 0 3 8 MN-MO ....................... 455006
1 0 A 7 0 7 3 MN-MO ....................... 41389S
1 0 A 7 1 0 3 MN-MO ....................... 471413
1 0 A 7 1 2 1 MN-MO ....................... 450083
1 0 A 7 6 1 1 WHITE ......................... 480954
1 0 A 8 1 1 MN-MO ......................... 470354
1 0 A 8 3 4 4 MN-MO ......................... 55563
1 0 A 8 4 6 8 MN-MO ....................... 450400
1 0 A 9 4 7 1 MN-MO ....................... 471883
1 0 A 9 7 8 9 MN-MO ....................... 473211
1 0 C D K 0 1 0 9 4 WHITE .................. 450400
1 0 C D K L 0 1 0 9 4 WHITE ................ 450400
1 0 P 2 0 9 1 MN-MO ..................... 411330N
1 0 P 2 0 9 7 MN-MO ....................... 353141
1 0 P 2 1 9 MN-MO .......................... 240356
1 0 P 2 2 2 MN-MO ............................ 65975
1 0 P 2 2 8 MN-MO .......................... 472234
1 0 P 2 4 1 7 MN-MO ....................... 473461
1 0 P 2 4 8 6 MN-MO ..................... 475003N
1 0 P 2 9 3 0 WHITE ......................... 473016
1 0 P 3 4 8 7 MN-MO ....................... 415379
1 0 P 3 6 0 4 WHITE ......................... 450073
1 0 P 3 6 2 MN-MO ............................ 40382
1 0 P L 7 7 2 MN-MO ........................ 470954
1 0 W A 0 1 0 9 4 WHITE ................... 323138
1 0 X 1 5 1 8 6 MN-MO ..................... 415960
1 0 X 2 3 0 2 8 MN-MO ..................... 455379
1 0 X 2 9 5 0 4 MN-MO ..................... 416271
1 0 X 2 9 7 2 0 MN-MO ..................... 455009
1 0 X 3 0 9 7 9 MN-MO ..................... 417205
1 0 X 3 1 3 1 1 MN-MO ..................... 471138
1 0 X 3 1 3 1 7 MN-MO ..................... 455146
1 0 X 3 3 8 4 1 MN-MO ..................... 203013
1 0 X 3 3 8 4 1 WHITE ....................... 203013
1 0 X 3 3 9 2 3 MN-MO ..................... 40301S
1 0 X 3 3 9 2 4 MN-MO ..................... 40160S
1 0 X 3 4 1 3 8 MN-MO ..................... 415447
1 0 X 3 4 1 3 8 WHITE ....................... 415447
1 0 X 5 4 8 7 WHITE ......................... 480954
1 0 X 5 5 2 5 MN-MO ....................... 450494
1 0 X 6 8 9 8 MN-MO ....................... 471413
1 0 X 7 0 6 MN-MO ......................... 450133
1 0 X L 0 9 5 0 MN-MO ..................... 471818
Hi Paul,
Your list is an awesome help! That steers me in the right direction, I can my local parts shops hunting some up now. Thanks a million!
Hi Thomas,
There's a local shop that I've worked with before that does excellent work. They remade the clutch in my Oliver 990, and it was a flawless job, so I'll have them rebuilt these brake discs too. They just need to know how thick to make the new linings.
Hi Lyndon
I believe I have the seals you need. New genuine Massey. Can you give me the part numbers of the ones you are looking for? I am in NW Saskatchewan.
my E-mail is open at bottom right...classic view.
Wayne
