u water pump
jr1983
I put a water pump seal in my utu. I filled the radiator but did not start it. Went out this morning and there was some drops of antifreeze coming out the weep hole. I have an it manual. What am I missing here? The shaft didnt seem to loose and I polished the seal surfaces with 600 grit. Any ideas?
I would guess that you missed nothing and just need to run it and let the seal and surface get to know each other. Be gratified that the weep hole is open and clear and working as intended.
Ok ill try it. The weep hole is clear after my seal went out and filled my crankcase with water. Always fun thanks.
