Difference between G1000 and G1000 Vista
Lots of differences. Fuel tank location, operators platform, hood/grill height, side console, tilt steering just to name a few.
Yes they did my dad had one a crenlo cab if I spelt it right but they were on from factory.
(quoted from post at 21:14:01 04/14/15) NO, NO this one has a piston pump and OPEN center hydraulics1
J. What kind of rear wheels does it have, typically the closed center tractors had the "taper lock" style wheels. Could someone have put the Vickers pump on the tractor? Possibly changed the rear ends out for another. As you would know isn't the Vickers pump a closed center pump? So what did they do with the case drain line? I would say its not OEM, but never say never.
I have 2 vistas with cabs both have 3 speeds. J as far as the open center hydraulics I am guess someone had trouble with the closed center and installed a open center on it.
