hydrolic pump
Rustyone
What are the gals per min on the hydrolic pump on a jetstar 2? Seams to me like it is really slow. Is there away to put a faster one on?
JSII hydraulic flow book figure 13.5 GPM at 1500 PSI at 1750 RPM steering flow 3 GPM +/- .5 at 1000 PSI. Do you know your pressure output, low pressure will make it seem slow. The pressure is very easily adjusted. jack
You find the specifications on page 3 of the JSII operators manual. You will find the adjusting procedure in paragraph 127 of I&T for Tele-flow system. If you have couplers installed just hook the pressure gauge to one of the couplers and pressurize.
