I'm looking to see how much interest there would be in a Overbore engine kit. Since trying to find oversized piston for Moline Side Valve Engines are about impossible. That the demand is High for Good used standard bore cylinder blocks. This kit will save a lot of headaches,time and phone calls.
It would allow for overhauls of that worn out or stuck engine with pitted cylinders. This revives the R and Z models making them run better than NEW having more Power and easier starting with higher compression.
The R tractors with EE engines will increase from 165cu.in. to 176cu.in.
The Zt tractors with RE engines will increase from 185cu.in. to 199cu.in
The Za and ZB tractors with the 206 engines will increase from 206cu.in to 221cu.in
The Kit would include 4 aluminum pistons with piston pins a 4 ring per piston ring set and a complete engine gasket set shipped any where in the U.S. for under $500. Let me know Thanks
