G705puller
New User
I'm wanting to know the value of a g1000 vista that paint looks
poor and has old cracked tires. And supposedly runs good.
Also the value of a M602 that has shinny but has minor flaws
in paint. Runs good with rebuilt fuel pump?
Thanks Chad
"LOCATION" Makes a big difference where the tractor is.
It is most likely worth more in Pekin, Illinois than it is in Peking, China
I'd say around 5500-8500 on g1000 in that shape
And m602 3000-5500ish depends on the tires
On the Vista, he says it supposedly runs good, what one guy thinks runs good and you think may be two different things. I would want to hear it start and run before I'd buy it as being good. If it spits and pops and smokes after a minute to warm up it probably will need work. When those engines were new they would start and purr along smoothly shortly after starting but if they have issues they can run pretty rough for a long time before smoothing out finally when revved up. Just my experience with them. A good one is worth some pretty good money but tires will set you back a bunch.
