3 speed Oliver tranny
I don't know if the 950 did but I know there were a few g1000s and m670s that had a three speed ample torque, wasn't the oliver over under thought, the 1355 and 955 are the only ones with the oliver over under, the other three speeds are MMs.
The G950 was available with a 3 speed amplitorque. The MM 3- speed was different than the Oliver/White 3 speed. The 3-speed amplitorque was optional around 1969, and could also be found on some Vista's, G1050's, 1350,'s and M670's.
Yeah they do not many were made and parts are hard to find, I don't know if you plan on making a puller or something but, the oliver over/under is tough to beat and you will be able to get parts easy and there a nice partial power shift that holds up well, I know the farmer pulls around here the Oliver's always hold up good in pulls because they can have three different speeds just moving a lever.
I am planing making a puller but I can't seem to find many 3 speeds for a good price Do you know the speeds for that 3 speed ampli-torq?
No, most where two speeds, you won't find a three speed there pretty scarce. Call justin Meyer 651-923-4029, he will have oliver over/unders and wont be priced bad, and will help with shipping if to far I'm sure.
