ZTU Question
1947 ZTU Question, I have to get to the crankshaft and at a minimum replace a rod bearing and I may have to take the crankshaft out to be machined. Is there any "easy" way to get to the crankshaft? Any information would be greatly appreciated!
Thanks in advance!
You can get to the crankshaft through the side cover on the left side of the engine. Then you can access the rods. In order to take the crank out you have to split the tractor and take the crankshaft out the rear of the tractor. Not sure of your location but I have a crank, rods and most everything for a ztu engine if you need parts.
