Is there anything that would cause the low on the ampli-torc to not work? It was years ago that I was told the low did not work on this tractor but I never did confirm it for myself. The reason I ask is that it seems to me that the low would also work as it is simply driven by the gears on the ampli-torc. I could understand the high not working if the discs were wore or broke as they would not lock the ampli-torc up in high then.
Can someone please explain to me how the ampli-torc actually works and confirm whether I am righ in assuming that the low end should always work as long as there is not a catastrophic failure within it or the transmission?
Thanks in advance for your help.
