stuck in 5th gear
rockrayl
New User
I have an old Moline tractor, that today I got it stuck in 5th gear. I can not go forward as I am up against my hay and I cannot get it out of gear. I took the shifter off and can move all but 1 of the gear arms. Any suggestions on how to get the last gear arm to move? This is my first time working on a tractor gear box.
If it is a later tractor, like a Jetstar, 445 or 4 star, pull the Amplitorque handle back to low range and see if it comes free. I have that stuck in gear problem sometimes with my 335 and Jetstar, but usually I am in the shed and the tractor is in 1st or 2nd gear.
If its one of the older tractors, try blocking one of the rear tires and jacking up the other rear tire, and turning the wheel backwards-assuming you were going forward when it stuck.
