Hydraulic oil foaming on Super M670
boel0091
New User
Need some advice. I'm worried that it's the hydraulic pump. Have changed couplers, filter, etc. Still have air in the system. No leaks. Advice? :roll:
There is a couple versions of hyd. systems used on S670's. Which do you have? Could be a pump issue but the filter setup has caused issues too. Dale 920 295 3278
It is a 1967 model year. As far as the difference in pumps, the only thing I know is that it is mounted on the motor (front). I really appreciate your advice. I'll have to check the filter setup over some more as well.
When you get chance call us @920 295 3278, if your setup is still original, we can help you make improvements in effiency ,also troubleshoot the pump if neccessary, Dale and Doug, riverdalefarmshop.com
Are you using atf/dextron 3 type fluid?
Change the filter with a wix, I think the number is 1828. Trim the bottom felt to make it "fit correctly".
Pressure wash and degrease the thing, somewhere around 3 times.
Get a chair and watch it run while cycling a cylinder and 3 point.
Make sure you age 1" line from the resivor to the pump (through the filter) has no leaks. This is important. In most cases air won't enter the system through a lean in the pressure lines. It's most likely if you have air it's from a place where the pump draws oil from.
Check for leaks and change the fluid and filter first.
