g950 g1050 turbo
LAG
1st Picture: 950 and 1050 turbo in field . these tractor work great making around 140 hp .950 has a shop built manifold garret turbo with a 504 engine . 1050 has a m&w setup on it.
2nd Picture: g1000vista lp g1000gas g950 g1050
Are you in Iowa, field looks like it, can you post picture of the other side of g950 and g1050 turbo, everything stuck under hood or did you have to modify it a bit. Most ones I've seen have a big pre cleaner on the outside but yours looks to be on top like it should be.
Very nice pictures. Does the G950 have a 504 engine clutch in it then? If I was closer to you I wouldn't mind plowing too. Any more pictures? What is the plow behind the G1000 Vista? A "D" series pull type plow?
How many horses? Will they roll the coal? Make any JD's look bad with that M&W? We seriously need to bring the hurt to the Deere's around here.
Really heard some good things about turbos on MM's... maybe they all need this.
