mm zb wide front
d21smith
Recently got a nice zb in on trade, thought I had a factory wide front and bolster but evidently don't anymore. Was wondering if anyone had a wide front and radiator bolster also for sale? Thank you
The axle will be the same but the bolster will be different on a UTE.I believe the bolster from a R or Z single front will work with the wide front axle. From a collectors standpoint I would leave it a narrow front because it won't have the correct serial number for a widefront. I have no room to talk because grandpa and I put a wide front under a ZBU because we couldn't find a ZBE, I have since found a ZBE and have yet to put the narrow front back under the other.
The axle itself is the same but the bolster is different the R and Z bolt to the front of the block where as the U has rails that go from side of block to side of bolster.
The original post that you answered was for an axel AND bolster. You said they were all the same.
MM DEL
