Superpicker
Helping a friend who has a brown mule Uni with a 2 row head. Sitting in barn not currently running but we need to move it to friend's house a few miles to get it running. Need to get the corn head locked up for transport as it is down on concrete barn floor. Can anyone tell me as friend seems to remember the head does not use a pair of hyd cylinders to lift head, uses a hyd cylinder(like implement cyl) with an undercarriage system to raise and lower it. If a guy could get a floor jack under the head and raise it, is there a way to lock/brace it in place with factory setup, or maybe I am going to have to rig up something. When head is up, going to try to pull gently out of barn with towstrap or chain around drive axle 100 feet then go from there. Unfortunately a now cold weather project.
If it had cylinders on the head, I could take cut angle irons and use lengthways and keep head in air.
Any ideas? Just looking for some before diving in. Thanks
Mule and head look similar to this one (not actually it):
