Sometimes I think im just full of unique problems. On my 1950 U the bar that holds my cultivator lift in place came off the other day and I did not realize it for a couple days. The hydraulic control leaver is frozed up so when the lift swings forward it pushes the hydraulic leaver to the up position. I used it around the shop a few times moving stuff around the lot and then I realized the crankcase is over full and the hydraulic is low.the weep hole by the water pump seems to have more oil coming out of it than usual. I took the pump off and I cant see anything leaking on the seal. What am I missing or did I blow the seal snd it will only leak under pressure?
